Date/Time: Thu, 27 Feb 2025 08:11:41 +0000
Web ICE & CME DIRECT
View Count: 1561
[2016-07-28 12:57:50] |
Robson - Posts: 76 |
please consider if possible to connect SC with Web ICE & CME DIRECT.
[2016-07-28 15:32:09] |
No, these are not supported. Data feeds from those exchanges are supported through the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed And various supported trading services: https://www.sierrachart.com/index.php?page=doc/Data.php#Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-28 11:09:47] |
User294224 - Posts: 43 |
Has the been any change or is it now possible to connect sierra chart with webice?
[2021-06-28 19:48:13] |
Sierra_Chart Engineering - Posts: 18584 |
No this is not supported.
