Date/Time: Sat, 23 Nov 2024 14:39:25 +0000
Fibbonacci auto retracement
View Count: 1477
[2013-07-18 11:20:12] |
User39642 - Posts: 1 |
Hello, I´d like to add fibbonacci auto retracement from list of available studies to my studies to graph, but I cant find them. I read that its possible to have f.a.retr. to view hod, lod, 50%rtrcmt but it is not in list. Thank you for answer, Radek |
[2013-07-18 17:41:43] |
Use the Auto Retracement/Projection study. It sounds like you are also looking for the Daily OHLC study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
