Date/Time: Sat, 23 Nov 2024 14:24:20 +0000
unmatched fill
View Count: 1684
[2013-07-15 14:28:08]
User31737 - Posts: 73
Is there any way to manually enter a fill in the Trades tab of Trade Activity Log in order to rectify an "Unmatched Fill"?
[2013-07-15 17:13:51]
Yes you can do this through Trade >> Trade Activity Log >> Edit >> Insert Trade Activity Entry. For the documentation, refer to:
http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#Controls
[2013-07-15 17:17:02]
I went through that drop down sequence, I see the edit button, however the line Insert Trade Activity Entry is grayed out. Nothing happens when I click on it.
[2013-07-15 17:18:46]
You need to select the Trade Activity tab before you can edit or insert Trade Activity entries.
