Date/Time: Sat, 23 Nov 2024 13:48:50 +0000
Monday GMT Pivot Points
View Count: 2658
[2013-07-15 12:19:25] |
PhilipJames - Posts: 34 |
I live in the UK and use GMT charts. How do I get the Monday Pivots to calculate using Fridays prices? Settings I currently use.. Settings and Inputs: http://screencast.com/t/ZMdDCOyRoWXK The chart settings http://screencast.com/t/CnmO4KX0 Data/Trade Settings http://screencast.com/t/8QlZq45U9 Thanks! Date Time Of Last Edit: 2013-07-15 12:20:02
[2013-07-16 00:53:19] |
M5amhan - Posts: 468 |
using Pivot Point - Daily study should work just fine.. however to make it more accurate select "use this intraday chart" to no, open a daily chart and select it in the pivot point settings under "daily chart #" to use Pivot Point - Variable Period in a more accurate fashion (weekly, monthly pivots) plot them directly on the daily chart, hide them, and use Study/Price overlay on your intraday chart to transfer them to your intraday chart |
[2013-07-16 01:11:42] |
There are 2 ways to do this: When using Pivot Points-Variable Period, you need to set the Auto Skip Period of No Trading input to Yes. Or use the Pivot Points - Daily study instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-16 01:12:27
