Date/Time: Sat, 23 Nov 2024 14:25:19 +0000
Volume displayed in Chart DOM
View Count: 1620
[2013-07-15 08:20:52]
Marmany - Posts: 307
Displayed bid / ask volumes in chart DOM ( V996 ) only changing when a trade is executed. Would like the volume to be updated in real time to align with TransActAT platform DOM.
Recall that it is possible on Sierra to have bid / ask DOM volumes refresh as they change but not able to locate instruction as to activation method.
Please advise.
[2013-07-15 09:04:31]
If you are on the latest Sierra Chart version, you will notice a TransAct icon in your system tray on your Windows taskbar. Right-click that to bring up the bridge interface window. You will need to uncheck the option to send ticks only. After that reconnect in Sierra Chart by selecting File >> Disconnect and then Connect to Data Feed.
Date Time Of Last Edit: 2013-07-15 09:05:04
[2013-07-15 09:34:51]
Many thanks for prompt reply. Problem solved.
Suggest you add this info to DOM section of Help Manual. I looked but was not able to locate.
[2013-07-15 09:53:58]
This is TransAct specific and should be on the TransAct Trading page and we will add it there.
Date Time Of Last Edit: 2013-07-15 09:54:21
