Date/Time: Sat, 23 Nov 2024 14:35:44 +0000
Using multiple versions of SC on one computer
View Count: 1541
[2013-07-14 14:59:53]
trader1 - Posts: 128
Is it possible to use both an older version and a new version of SC on the same computer? If so, will installing the latest version disrupt the older version in any way if it it installed into a different directory?
Thanks.
[2013-07-14 21:35:50]
Kiwi - Posts: 375
If they are installed in different directory structures (ie, SierraChart\ and SierraChart2\) then one instance of SC has no effect on another.
I frequently have multiple versions running with no problems trader1.
Date Time Of Last Edit: 2013-07-14 21:39:23
[2013-07-14 21:44:47]
Yes you can do this. There will be no conflict.
