Date/Time: Sat, 23 Nov 2024 14:03:37 +0000
Barchart.com extended tick data
View Count: 1833
[2013-07-12 20:35:50]
User66297 - Posts: 12
I am using Sierra charts with Barchart.com as the data provider. I have subscribed to their extended tick data for equities going back to 1 year (not the standard 1 month tick data package). However, from the message logs, I see that Sierra Charts is loading up Tick data only going back to 1 month from barchart and loading up Minute data for the rest.
How do I make sure tick data is loaded up going back to 1 year?
Thanks!
[2013-07-12 21:29:09]
We were not aware the Barchart data service had this, we will need to add support for this. We will have a new release out this evening.
After you update, you will need to follow through the instructions in help topic 42 here for this:
http://www.sierrachart.com/index.php?l=doc/helpdetails42.html
[2013-07-12 22:24:12]
Thanks for the quick reply and the fast fix!
[2013-07-13 04:50:45]
Thanks a lot for adding support for this so quickly! I do see tick data being loaded up now for the full year!
[2013-07-13 09:02:23]
OK
