Date/Time: Sat, 23 Nov 2024 14:07:34 +0000
Volume Bars
View Count: 1580
[2013-07-12 18:19:13] |
100 - Posts: 147 |
I've been looking at / using SC's up vol down vol lately, and I could help but notice tht there are times when the up vol down vol, simply doesn't display a volume... Can you help me understand how I can fix this?
[2013-07-12 23:39:09] |
Refer to the documentation for these studies here: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-13 03:02:43] |
100 - Posts: 147 |
The main volume indicator takes all volume and assigns it a positive or negative value. Concerning the main Volume Indicator: Is there is no way to distinguish up volume, from down volume, using spreadsheets? The up volume / down volume indictors force me to choose between prev bar close and current bar open, and both options leave me with out the full picture, that the main volume indicator gives. Is there a way around this problem? What can I do to see the main volume indicator's version of up vol/down vol (in spreadsheets)? |
