Date/Time: Sat, 23 Nov 2024 13:52:54 +0000
Horizontal ray ~ label disappears
View Count: 1761
[2013-07-12 09:32:18] |
User96105 - Posts: 113 |
Hi ~ when I cut short a horizontal ray the label disappears. Is this correct? Thanks
[2013-07-12 12:26:32] |
Yes, this does make sense because it is no longer a Ray.
[2013-07-12 15:52:51] |
So a line which is no longer a ray is not entitled to a label?
[2013-07-15 04:18:03] |
Yes.
