Date/Time: Sat, 23 Nov 2024 12:40:12 +0000
Global Chart Drawing Font
View Count: 1513
[2013-07-12 08:32:22] |
User96105 - Posts: 113 |
Hi ~ Firstly I'd like to say again what a great platform Sierra Chart is ~ many thanks. I can't see a way of changing the colour of the drawing font ~ I can change the font/style/size in Tool Settings, but not the colour. Please advise. Thanks. |
[2013-07-12 08:35:32] |
For what Tool? Anyway, you do this individually for the drawing tools under Global Settings >> Tool Configs. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-12 08:36:30
[2013-07-12 08:54:35] |
This is for the rectangle where I use labels ~ but I see that the only way to change the colour of the font is change the outline colour of the rectangle. It would be good to be able to change this globally in Tool Settings (or to be able to select a global over-ride colour+background). Thanks |
