Date/Time: Sat, 23 Nov 2024 12:49:18 +0000
Broker Sierra Chart platforms (e.g. Velocity)
View Count: 1488
[2013-07-11 23:05:57] |
Ares_Bowman - Posts: 5 |
Hi, I am wrapping up my trial version of Sierra Chart and would like to continue using Sierra Chart instead of my previous platform (NinjaTrader). My broker is Velocity Futures. If I license Sierra Chart through Velocity can it still connect to multiple data feeds? I would like to have my DOM connected to Velocity and my chart data populated by my DTN IQFeed connection. I know that I would have to run 2 instances of the software, but I'm wondering if I can do this with the Velocity Sierra Chart or if I need to license directly through Sierra Chart and use the FIX connection? Thanks |
[2013-07-12 00:28:33] |
No. You will need to have a direct account with Sierra Chart to connect to multiple Data and Trading services other than Velocity. See: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
