Date/Time: Sat, 23 Nov 2024 12:32:42 +0000
Chartbooks are mixing with each other
View Count: 1555
[2013-07-09 14:33:03] |
EuropeanTrader - Posts: 290 |
Hi, I have multiple chartbooks opened and each and every one of them has couple of charts from the first chartbook opened (when switching between them I always see few charts from chartbook 1, in all other 10). thx |
[2013-07-09 20:54:55] |
This is because those charts that you always see no matter which Chartbook you switch to have Window >> Chart Window Always Visible enabled.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-09 20:55:29
[2013-07-12 06:56:17] |
yes, that solved the issue. thank you!
