Date/Time: Sat, 23 Nov 2024 14:21:40 +0000
[User Discussion] - Linux: Mouse Buttons
View Count: 1718
[2013-07-09 02:33:14] |
Kiwi - Posts: 375 |
:: User Discussion :: I use a logitech trackball which has buttons 8 and 9. Under windows they were mapped and usable. But Logitech doesn't supply Linux drivers so I thought they were unusable. That's a shame because I used them for position alignment and other functions in Sierra Chart (button press and ctrl button press gave me 4 combinations of mouse to key combination to drive SC). Then I discovered btnx which is a daemon/gui combo that allows you to map your mouse buttons to actions or key combinations. http://awesomelinux.blogspot.com.au/2012/08/btnx-for-ubuntu-1204-precise.html I post that just in case anyone else had lost some mouse functionality for getting the most from Sierra Chart. |
[2013-07-19 05:55:27] |
TPeirce - Posts: 27 |
Kiwi, Would you take a look at an issue I'm having with how true data time stamps are in Intraday Editor as opposed to the time line in recent versions of Sierra Chart? For some reason they are different. The picture in the last post is of version 982. Timeline Display with IB 5-Second Data |
[2013-07-19 07:35:34] |
Kiwi - Posts: 375 |
I don't understand what the problem is - mine seems ok.
