Date/Time: Sat, 23 Nov 2024 10:55:30 +0000
Mutliple targets
View Count: 1465
[2013-07-08 18:30:01]
User86222 - Posts: 10
In the DOM, I want to do a 4 qty order. For when I click buy or sell on market, I want 2 of the qty to go to the 1st target offset and the other 2 qty to have the stop moved up to BE. All qty need to have the same stop loss at start.
Then for the 3rd contract, it should go to higher target, and the 4th contract should go to a higher target than the 3rd contract. As noted the 3rd and 4th contract will have stops at BE if the 1st and 2nd contracts hit their targets. However, I don't need the stop to move up any more once it reaches BE.
Can you explain how to set this up and save it so I can use this type of order every time I trade?
[2013-07-08 19:30:45]
Still waiting for an answer, does anyone here actually know how to use this trading platform?
[2013-07-08 22:09:19]
Sierra Chart - Max - Posts: 5730
To use the attached Trade Window Configuration file, please refer to the documentation here:
https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#ConfigurationFileAnotherSource
Sierra Chart Support
Date Time Of Last Edit: 2013-07-08 22:10:11
attachment2TargetsWithBEStop.twconfig - Attached On 2013-07-08 22:10:07 UTC - Size: 6.18 KB - 601 views
