Date/Time: Sat, 23 Nov 2024 11:28:47 +0000
Interactive brokers - trading from the chart in the Sierra chart
View Count: 1445
[2013-07-07 14:54:52] |
User39696 - Posts: 6 |
Hello, I would like to ask you. I have Interactive brokers account (IB) and I trade in SIM mode with IB data and I enter orders right in SC chart. If I want to trade live and still enter orders in SC chart, is there anything what needs to be set or done (except switch of the SIM mode in SC) before I will start live trading? Thank you for your answer. Have a great day! Martin Vlcek |
[2013-07-07 21:22:04] |
You just need to disable Trade Simulation Mode. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim Also, make sure that you are logged into Trader Workstation with your live account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-07 21:25:19] |
Sierra Chart - Max - Posts: 5730 |
Yes, if you switch off trade Simulation mode, orders entered will be sent directly to the IB account you have entered under "File >> Data/Trade Service Settings". Also, make sure you have reviewed the Overview of Trading documentation here: https://www.sierrachart.com/index.php?l=doc/doc_Trading.html Sierra Chart Support |
