Date/Time: Sat, 23 Nov 2024 10:58:37 +0000
RVI Indicator [Relative Vigour Index)
View Count: 2123
[2013-07-06 20:22:43] |
User37170 - Posts: 29 |
The indicator is calculated by using the following formula: RVI = Close - Open / High - Low How best to achieve this in SC ?? K. |
[2013-07-06 21:35:00] |
M5amhan - Posts: 468 |
http://www.sierrachart.com/image.php?l=1373146488907.png is that right? |
[2013-07-07 06:26:56] |
Hi there, Hard for me to comment. Looks promising but then looks are deceiving. Perhaps if you could let me have the study / settings / steps used to get this result.... ? If I can set it up somehow myself I will be able to comment more accurately. Also I don't recognize the security used.....so a blind comparison wont work. However , if you have more detail I am sure we could solve this by agreeing on a common security that we both have access to. K. |
[2013-07-07 08:14:24] |
This is a simple formula. We will add this to the next release of Sierra Chart . This should be available in the next few days.
