Date/Time: Sat, 23 Nov 2024 10:45:32 +0000
Data Snooping??
View Count: 1840
[2013-07-06 17:36:41]
User15451 - Posts: 27
Dear Support,
I have realized my error and was wondering how to fix data snooping?
Currently i have a simple moving average from a longer time frame overlayed on a chart.
Then i have a spreadsheet for trading on the shorter time frame chart for trade signals.
Running my first couple of backtests i realized the amazing results were because of data snooping errors.
How can i fix this and still use two time frames? IE 1 minute with 10 minute???
Your help is greatly appreciated.
[2013-07-08 23:40:26]
Sierra Chart - Max - Posts: 5730
If you are using the Study/Price Overlay study, then refer to the documentation here:
https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s118
There are many inputs which control the referencing of data between the 2 charts.
Sierra Chart Support
Date Time Of Last Edit: 2013-07-09 00:58:56
[2013-07-09 02:12:23]
Kiwi - Posts: 375
:: User Discussion ::
Max's information is valid and useful; it might be that you require an alternative view depending on what you are trying to do.
Are you talking about automation or a visual discretionary issue User?
