Date/Time: Sat, 23 Nov 2024 14:23:41 +0000
Zoom In
View Count: 1661
[2013-07-05 19:08:07] |
User39772 - Posts: 311 |
I load 30 days of intra day data into a 3 minute chart. I can croll from right to left to see al that data but I can non zoom in to make all 30 days or a fragment of that visible. Is there a limitation re. zoom in feature ?
[2013-07-06 00:40:27] |
Refer to Working with Charts here: https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-18 17:46:39] |
I found Decreeasing Bar Spacing but there seems to be e limit to which data available can be compressed. E.g. on a 5m chart I can only compress to 5 days even there is more data available. How can I solve this ?
[2013-07-18 17:57:05] |
What is the logical answer? If there is no longer any space between the bars, the next step is to increase the timeframe of the bar.
