Date/Time: Sat, 23 Nov 2024 11:24:52 +0000
deleting jul 4 from charts
View Count: 1712
[2013-07-05 18:33:12]
User77503 - Posts: 48
is there a way to delete jul 4th's 2 hr session from my charts?
[2013-07-05 22:26:32]
Yes. You can exclude the particular date through Chart >> Chart Settings. Refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#DatesToExclude
[2013-07-05 22:44:17]
awesome thanks! follow up question- is there a way to have a chart only show the RTH volume instead of 24 hrs?
[2013-07-06 01:00:28]
The question is not completely clear. If are referring to the Session Times, refer to:
https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes
[2013-07-06 01:03:14]
sorry- all my charts for the ES I have set for RTH session only. However, the total volume that is displayed on the top of the chart is for the full ETH session. is there a way to get only the RTH volume displayed?
[2013-07-06 01:33:50]
No. Unless you were to set the chart to 1 day per bar, then you could look at the volume for the bar.
Date Time Of Last Edit: 2013-07-06 01:34:28
[2013-07-06 11:24:47]
ok, so in the attached image I have a candlestick chart with each candle set to one RTH session for the ES. I hovered over yesterdays candle and in the "Chart Values" header it gives me the open, close, hi, lo etc. I see "V:1114438 T:325082 BV:540238 AV:" so I can assume the "V:1114438" is yesterdays RTH volume? What are the other two values?
http://www.sierrachart.com/image.php?l=1373109580547.png
[2013-07-08 23:34:36]
Sierra Chart - Max - Posts: 5730
Yes.
Refer to:
https://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#RegionDataLine
Sierra Chart Support
