Date/Time: Sat, 23 Nov 2024 11:34:49 +0000
[User Discussion] - tool button to clear or temporarily hide all studies
View Count: 1979
[2013-07-03 23:51:54] |
steve i depner - Posts: 14 |
Checking to see if there is a tool button to clear (or hide temporarily) all studies on a chart? Many thanks in advance |
[2013-07-04 00:09:48] |
No. You need to select Analysis >> Clean Chart to remove the studies. You should also have another study collection with all the studies you can use to put them back. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-04 01:36:37] |
ganz - Posts: 1048 |
steve i depner hi i've shared the exmpl https://www.bigmiketrading.com/sierra-chart/26630-hide-show-studies-buttons-study.html gd lck Date Time Of Last Edit: 2013-07-04 01:40:50
