Date/Time: Sat, 23 Nov 2024 11:16:35 +0000
[User Discussion] - Colour Price Bars.
View Count: 1833
[2013-07-03 09:27:41]
User74484 - Posts: 6
I use Renko bars and want to colour them when price reverses x number of points.
For instance, if a 4 Renko bar closes and then reverses 12 points I want the bar to change colour -
and then so on etc.
What colour bar study should I use and how do you write the code etc.
Many thanks.
[2013-07-03 11:07:58]
For this you need to use the Color Bar Based On Alert Condition study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s252
We do not write formulas. You will need to work out the formula.
[2013-07-03 13:19:17]
Sawtooth - Posts: 4118
Try this:
Add two instances of the Color Bar Based On Alert Condition study, one for each color/direction.
Put this in the Alerts tab of the 'go long' instance:
=AND(C[-2]<O[-2],C[-1]>O[-1],C>O)
Put this in the Alerts tab of the 'go short' instance:
=AND(C[-2]>O[-2],C[-1]<O[-1],C<O)
This only works if the reversal amount is 3 times the renko bar size.
[2013-07-03 19:20:40]
tomgilb - Many thanks for your reply, but I cannot get it to work. I get an error message "Invalid formula".
But thanks for trying. ( Which is more than can be said for SC support!!)
[2013-07-03 23:27:21]
M5amhan - Posts: 468
it does work i just checked it
see attached picture
Date Time Of Last Edit: 2013-07-03 23:29:02
imageCL.PNG / V - Attached On 2013-07-03 23:29:00 UTC - Size: 33.45 KB - 554 views
[2013-07-03 23:43:19]
User74484, don't type the formulas; copy/paste them. That way there will be no typos.
