Date/Time: Sat, 23 Nov 2024 11:30:59 +0000
FXCM vs FXCM
View Count: 1810
[2013-07-02 16:58:19]
user85017 - Posts: 37
Can you tell me the difference between FXCM FIX Trading ( trading and FXCM Data (trading
[2013-07-02 17:03:31]
You need to use FXCM FIX trading.
The service named "FXCM Data" does support trading, but it is being discontinued.
For the instructions to use FXCM FIX, refer to:
https://www.sierrachart.com/index.php?l=doc/FXCMTrading.php#Setup
[2013-07-02 17:16:06]
ok thanks
