Date/Time: Sat, 23 Nov 2024 08:44:21 +0000
spreadsheet help needed...true/false to 1/0
View Count: 2056
[2013-07-01 17:07:48] |
User22396 - Posts: 191 |
sorry but i am totally spacing on this and have been wasting to much time tryin to get this sorted...any help aprreciated...i guess summertime brain melt i am tryin to count occurences using spreadsheet study and then run some real basic stats...like number of times somthing occurs in a day/30d period etc etc...using the basic true/false but am havin a hard to getting it to flip to 1/0 so i can sum etc...for example say a 5min bar closes on it high- how many times a day, avg times over 30days, percent times it occurs, any follow thru in points/in bars etc etc i have seen it done in IRT tho not this example but similar jsut counting true/false... http://www.linnsoft.com/homework/ and wasnt sure how to most easily recreate in SC anyone ever create a spreadsheet or work it this way for SC? thanks b |
[2013-07-01 23:12:52] |
What you want to do in this case is use the IF function and have it return 1 when the Condition expression in the function is TRUE and 0 if FALSE. Here is the documentation: https://www.sierrachart.com/index.php?l=doc/doc_WorksheetFunctions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-01 23:13:12
