Date/Time: Sat, 23 Nov 2024 08:48:36 +0000
eraser tool
View Count: 1365
[2013-06-30 08:51:59]
4646ed - Posts: 230
didn't you used to have an eraser tool? if you did can you bring it back, if not can you make one? erase drawing mode just adds extra work to something that should be more straightforward -- point and click and erase any drawing or text you've added to a chart. also, right click and select to erase drawing is also extra work.
[2013-07-02 00:27:05]
There are many methods to do this. Refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ErasingChartDrawings
