Date/Time: Sat, 23 Nov 2024 08:59:52 +0000
Last Traded Price for Historical Data
View Count: 1700
[2013-06-29 20:12:10] |
User38705 - Posts: 1 |
Is it possible to get the last traded price instead of the settlement price for the data downloaded for continuous contracts through SC Historical Data service? I need the last traded price as quite often the settlement prices are decided hours before trading ends (e.g. EUREX settlement price is calculated at 1730 CET while the trading goes on till 2200). I have also noticed that continuous contract data has periods where volume is very low e.g. for PA# volume drops significantly towards the end of May & keeps on going down (there are quite a few other period like this earlier in the year). I have compared this data with daily bars from CQG & I don't see the drop in volume. Could this indicate that the continuous data has period when immediate expiry contract is not used? Thanks, Ben |
[2013-07-01 21:24:10] |
We will get to this shortly. We are working on some documentation updates.
[2013-07-01 23:43:24] |
1. Refer to the documentation at the bottom of this page: http://www.sierrachart.com/index.php?l=doc/helpdetails12.html#h12.7 2. The continuous contract symbols you are using, always include data from the nearest expiring contract. For more information about this, refer to this page: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html You will want to use "Method 1" instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-01 23:43:47
