Date/Time: Sat, 23 Nov 2024 16:47:11 +0000
Rithmic data connection issue
View Count: 2079
[2013-06-29 19:40:06]
User96105 - Posts: 113
Hi, this is a great trading platform, many thanks.
Recently my connection to Rithmic data has been stopping every 30 minutes with this log entry:-
“You have not placed an order within the last 10 days. The trading service you are using requires that you trade....”
I've contacted Optimus about this assuming it was a Rithmic issue, but they say to contact Sierra.
Many thanks,
Tony
[2013-06-29 22:51:45]
Please update to the latest version by selecting Help >> Download Prerelease. The notice will now only show if there is 15 days of no trading.
To avoid this notice, submit an order when not in Trade Simulation Mode and then cancel it if you want. It can be a limit order that is away from the market. If you need help with submitting order, let us know and we will give you instructions.
You can even submit an order over the weekend. As long as you put one in, that is all that is necessary even if it gets rejected.
Here is the overview of trading page:
https://www.sierrachart.com/index.php?l=doc/doc_Trading.html
If Sierra Chart users are not trading enough, then all Sierra Chart users will be cut off from Rithmic and Zen fire by the end of this year. We have been warned.
Date Time Of Last Edit: 2013-07-19 18:18:04
[2013-06-30 17:30:46]
Great, thanks. I'm just finishing testing a strategy, so should be trading in the next week or so.
[2013-08-18 11:38:03]
Hi, I'm still not live trading as it's taken me longer than expected to test my strategy. I've just tried to log on to place a "live order" over the weekend, but no joy (see below from the log). Have Rithmic stopped this method circumventing their system?
GSP - Port for executable: 15867 | 2013-08-18 06:10:55
GSP - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-08-18 06:10:55
GSP: Connecting to the server 127.0.0.1. Port 15867 | 2013-08-18 06:10:57
The network socket is connected. | 2013-08-18 06:10:57
GSP: Connected to server. | 2013-08-18 06:10:57
GSP: Sending logon request message. | 2013-08-18 06:10:57
GSP - Starting the connection process to data and trading service. | 2013-08-18 06:10:57
GSP - Logging is enabled. Log file: Rithmic.log | 2013-08-18 06:10:57
GSP - Connecting to Rithmic Production server. | 2013-08-18 06:10:57
GSP - Alert Message: Market Data Connection Opened. | 2013-08-18 06:10:59
GSP - Alert Message: Market Data Connection Login Failed. permission denied | 2013-08-18 06:10:59
GSP Server Info - Server Name: . Server Version: . Provider Name: . | 2013-08-18 06:10:59
GSP - Server protocol version: 2. Client protocol version: 2. There is a protocol match. | 2013-08-18 06:10:59
GSP connection error | 2013-08-18 06:10:59
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-08-18 06:10:59
To prevent further connection attempts, select File >> Disconnect. | 2013-08-18 06:10:59
GSP: Disconnected from the server. | 2013-08-18 06:10:59
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-08-18 06:10:59
[2013-08-18 12:26:31]
Contact your broker about this:
