Date/Time: Sat, 23 Nov 2024 09:07:00 +0000
992
View Count: 1543
[2013-06-28 19:16:28]
User39772 - Posts: 311
Hi I updated to 992 today. Since that my TuS is empty and the bid ask lines in the chart disappeared.
[2013-06-28 23:04:29]
Make sure you have specified the Alternate Real-time Update Symbol in Chart >> Chart Settings.
Date Time Of Last Edit: 2013-06-28 23:04:40
[2013-07-01 13:35:28]
Hello, this seems to have nothing to do with Alternate Real-time Update Symbol because:
1st in the earlier versions this field always was empty
2nd if i enter a symbol into this field now nothing changes, no DOM on chart and no TuS
[2013-07-02 01:07:13]
How do you have Global Settings >> General Settings >> Use Non-Chart Data from Remote Instances set?
Does the chart use data from a remote instance/copy of Sierra Chart?
Date Time Of Last Edit: 2013-07-02 04:26:52
