Date/Time: Fri, 27 Sep 2024 05:19:51 +0000
8-02-2016
View Count: 650
[2016-02-08 15:54:30] |
julian pineda - Posts: 60 |
What is happening with the platform?
[2016-02-08 16:02:21] |
Please be specific about the problem. However, we see you are using the service GAIN Capital (OEC Trader) FIX. OEC had a problem earlier and it is now resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
