Date/Time: Fri, 27 Sep 2024 05:18:11 +0000
Get DateTime of BaseGraphData
View Count: 918
[2016-02-08 14:26:52] |
User96015 - Posts: 55 |
Dear sir, I' m not able to find function which gives date and time of a specifed index in a basegraph data. SCGraphData BaseGraphData; // Get the base graph data from the specified chart sc.GetChartBaseData(ChartStudy.GetChartNumber(), BaseGraphData); int index = 20; BaseGraphData[Index]. //Function Can you help me? Thx |
[2016-02-08 16:16:52] |
I'm reading again my question. Maybe it' s not expalins very good. Do u understand or can I have to write question better? Ty. |
[2016-02-08 18:22:38] |
You need to use this function: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetChartDateTimeArray Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
