Date/Time: Fri, 27 Sep 2024 05:13:06 +0000
Ver.1366
View Count: 712
[2016-02-07 20:09:34] |
Dennis B. - Posts: 263 |
As per instructed tried to download ver.1366. Got a message "Download to software update has been redirected" then nothing happens ??
[2016-02-07 20:16:41] |
It will take some time for the download to complete. Refer to: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
