Date/Time: Fri, 27 Sep 2024 05:15:54 +0000
Percentage line from the top
View Count: 628
[2016-02-07 19:51:11] |
Kinobe - Posts: 86 |
Hi I would like to have a line at 3% from the top of the intraday chart. how can I manage this? thank you |
[2016-02-07 20:20:22] |
Not sure how this would be done because the top value of the scale can change. There is currently no study in Sierra Chart that does this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
