Date/Time: Fri, 27 Sep 2024 05:20:09 +0000
Could not get connect
View Count: 656
[2016-02-07 01:55:56] |
User679979 - Posts: 1 |
Hi, I got this evaluating package 5 for 20 days, but I just could not get connect, please help for this. And What does evaluating 5 included? and what other packages does Sierra has, and what's the difference? Thanks, |
[2016-02-07 18:28:03] |
For help with the connection problem we need to see the Message Log. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog For what is included with Sierra Chart Service Package 5, refer to: Description of Service Packages and Pricing: Packages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
