Date/Time: Fri, 27 Sep 2024 05:18:20 +0000
Turning off the crosshair when using other tools
View Count: 704
[2016-02-06 19:13:58] |
User66804 - Posts: 14 |
Is there anyway of turning off the temporary crosshair when using the other tools such as: line, Ray, etc... I know in older versions this was not the case. I have been using build version 1295 for this reason, but feel that there are many other new functions that I may want to use. Any light that you could shed on this issue would be greatly appreciated.
[2016-02-06 20:46:04] |
Yes, the options for this are in Global Settings >> Tool Settings >> Chart Values. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
