Date/Time: Fri, 27 Sep 2024 05:15:20 +0000
Version 1366
View Count: 684
[2016-02-06 12:58:41] |
wingz - Posts: 121 |
Got a notice that 1366 was available for download. I did the install process twice. In the help menu ...........it's telling me that I'm still using version 1307. On the first attempt, I unchecked Microsoft Redistributable.........on the second attempt I left it checked. Also..........Sierra is STILL connecting to my data feed on startup.....even though I have that option unchecked. I would really like to find out why it's doing that.
[2016-02-06 18:26:25] |
When you update you need to use Help >> Download Current Version (New Spreadsheets)
