Date/Time: Fri, 27 Sep 2024 05:13:02 +0000
Associated Watch List
View Count: 639
[2016-02-06 12:25:16] |
User190756 - Posts: 38 |
I created an Associated Watch List and took some notes and lines. When I change the symbol, there are the same notes and lines as the symbol before. What to do? |
[2016-02-06 18:59:27] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
