Date/Time: Fri, 27 Sep 2024 05:17:27 +0000
daily change and daily percent data starting at incorrect time
View Count: 1216
[2016-02-05 20:03:00] |
User101796 - Posts: 6 |
Hello, so I had no problem setting global session times for ESH6 and RLM-MH6 and the daily change amount and percent works fine on those two symbols, however, GCLH6 still incorrectly ends my session at what I think is the pit session close. Here are my settings for that ticker: http://i.imgur.com/NAgZQhb.png Should end at 2pm pacific and reopen at 3pm which it does on the daily candles but intraday it just resets my daily % and amount change at 11:30 (I believe. I missed when it happened but as of right now, 12:11 pacific, the daily change and percent are not correct). daily bars are forming at correct time but the data on the top is incorrect: http://i.imgur.com/Ap6z8Aq.png intraday: http://i.imgur.com/GfYzmwV.png can you please tell me what i'm missing? Date Time Of Last Edit: 2016-02-05 20:11:31
[2016-02-05 21:36:46] |
Refer to the documentation here for these fields: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#RegionDataLineDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
