Date/Time: Fri, 27 Sep 2024 03:45:51 +0000
sierra chart autocenter
View Count: 701
[2016-02-05 14:27:07] |
toews&kane - Posts: 209 |
Hi, When I scroll back in time in a chart it does not auto center it, is there a way to fix that? Cheers |
[2016-02-05 18:04:57] |
You need to enable this option for the main price graph scale: Constant Range Scale: Re-Center on Chart Scroll Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowMainPriceGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
