Date/Time: Fri, 27 Sep 2024 03:54:07 +0000
Studies Disappeared
View Count: 905
[2016-02-05 14:07:53] |
sigmadict - Posts: 95 |
Hello, I don't know what happened but I had a lot of studies on a Saved Chartbook, and all of the sudden, my Study Collection (that I had not saved) was empty. I tryed to reconnect without saving, but it did not help. 1- Any idea what could have happened ? 2- Any way to get my studies back (collection not saved) ? Regards |
[2016-02-05 14:10:06] |
Also I was on Volume Chart in my Chartbook, and when I open the Chartbook now it opens on 1 min Timechart. I did not save the Chartbook, but it's now the settings. Regards |
[2016-02-05 15:34:05] |
Hello, I am on version 1358. I did try to save a Study Collection and then use it with : -Analysis Tab, Select the Study Collection All the Studies Disappeared again. So I load up the Chartbook again, because I did not save it, and the Studies came back. Tryed to use : Analysis : Select a different Study Collection, Disappeared again. Tryed to save it again, on a fresh Start, saved the Study Collection, Switched Analysis, and it worked. I don't know if there is a bug with Analysis Tab. I realised that, when you Save the Study Collection with the ' Save Single ' button (under Chart Studies), it does not save, and all the Studies are gone if you switch with Analysis tab. But if you save with ' Save All ' button (under Chart Studies), it does save. Hope it can help. Regards |
[2016-02-05 15:46:02] |
Updated to version 1366. Even my orders did not get Filled on 1356. I don't know what happened to that version this morning, but weird. My orders get filled on 1366. The Problem with Analysis tab with Version 1366 is still there. Regards |
[2016-02-05 18:46:53] |
In response to post #1, refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#RestoringPriorStateOfChartbook We see no problem with saving a single study as a Study Collection. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
