Date/Time: Fri, 27 Sep 2024 03:56:18 +0000
Spreadsheets Replay - enters trade on bar open vs the formula
View Count: 708
[2016-02-05 13:27:53] |
SSGill - Posts: 36 |
On Replay, both methods, Standard and Accurate Trading System Back Test Mode, the buy and sell entries are executed at the bar open, and not when the condition is met in column K or M. However, the when the position closes the trade in column L, or N it does do it correctly, when the criteria is met. I have attached a image to show the Trading Activity Log, and it shows the entry of a trade at the bar open, :00 seconds, but the close of the trade at the correct time, I verified this by opening a chart in 1 second increments. |
Capture.PNG / V - Attached On 2016-02-05 13:25:40 UTC - Size: 32.77 KB - 262 views |
[2016-02-05 18:28:23] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#SignalOnlyonBarClose Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
