Date/Time: Fri, 27 Sep 2024 03:57:04 +0000
I can't change volume profile percentage for value area in TPO chart
View Count: 913
[2016-02-05 08:56:02] |
JingIt - Posts: 44 |
I can't change volume profile percentage for value area in TPO chart when I create in new Chartbook, my old chart book working fine. Every time I change to 70 and click apply, it turn back to 1 every time. |
[2016-02-05 09:02:57] |
This does not make sense. We have never heard of anything like this and cannot reproduce the problem. We recommend removing the Volume by Price study from the chart and adding it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-05 09:13:19] |
I don't know why this happen to me, Video can show more than what I said, I also attach the Chartbook for the chart I got the issue. https://www.youtube.com/watch?v=FC3xywZE5vk&feature=youtu.be |
ESPA.cht - Attached On 2016-02-05 09:09:46 UTC - Size: 470.36 KB - 325 views |
[2016-02-05 09:34:55] |
Refer to the documentation here for that setting: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#ValueAreaPercentage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-05 09:37:11] |
Ah, I see the problem, thank you, fixed.
