Date/Time: Fri, 27 Sep 2024 03:48:47 +0000
Multiple monitor: "Trade Window for chart" missing
View Count: 1351
[2016-02-05 01:44:42] |
User266903 - Posts: 26 |
My laptop has one monitor attached by HDMI and another over a USB Display Adapter. On one of my charts, if I "Open Trade Window for Chart", it is nowhere to be seen. I suppose it is opening somewhere off screen. I can "Attach Trade Window to Chart", to get it back, but as soon as I detach it from the chart, it is nowhere to be seen, and I am assuming is open somewhere off screen. How do I capture this runaway "Trade Window"? Thanks!
[2016-02-05 04:05:55] |
Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowMissingDoesNotAppear Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-05 04:07:14] |
Yes!
