Date/Time: Fri, 27 Sep 2024 03:50:01 +0000
How to Use Gann Fan The Correct Way
View Count: 1582
[2016-02-05 00:34:24] |
User329725 - Posts: 1 |
The instruction on Sierra Chart Help section are below: To use this tool, left click with your pointer on the chart to start the lines at a significant point. The angled lines are drawn from this point. Move the Pointer several bars towards the right to extend the angled lines towards the right then left click again with your Pointer. *************************************************************************************************************************** What confuse me is the second paragraph: At what point moving to the Pointer to the right should I stop? If I start at a Swing Low, the instruction above is not clear where to stop my next point. The second paragraph is very vague. Help Please. Ernie |
[2016-02-05 03:54:03] |
We have updated the documentation to explain this. Refer to the updated documentation here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GannFanTool Be sure to reload the page to get the updated information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
