Date/Time: Sat, 23 Nov 2024 07:17:43 +0000
Two contracts
View Count: 1446
[2013-06-27 20:29:35] |
user87297 - Posts: 6 |
Hi, How can i load 2 contracts to the same chart it is call "Price Differnce" Between 2 contracts (like CL of July 2013 to CL of August 2013) Many Thanks. Amos. |
Crude Oil.jpg / V - Attached On 2013-06-27 20:29:20 UTC - Size: 99.22 KB - 549 views |
[2013-06-28 03:14:03] |
This can be done by using the Difference (Single Line) study which is documented here: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
