Date/Time: Fri, 27 Sep 2024 03:49:38 +0000
How can I change setting of the interactive scale to auto move with last price?
View Count: 643
[2016-02-04 17:02:16] |
User935018 - Posts: 8 |
How can I change setting of the interactive scale to auto move with last price. In my Sierra chart platform when the price go up or down I have to move interactive scale manually, I would like to change it to automatic follow the last price. Thank you |
[2016-02-04 18:45:51] |
You need to set the chart Scale Range to Constant Range with the Auto Centering option. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-04 18:46:15
[2016-02-04 18:51:27] |
Great, Thank you
