Date/Time: Sat, 23 Nov 2024 07:51:10 +0000
stop lock option
View Count: 2044
[2013-06-27 20:23:25]
Frontrunner - Posts: 20
hello support,
is there an option to "lock" my stop from enlarging once it is adjusted?
thanks
[2013-06-27 21:18:23]
The question does not make sense to us.
[2013-06-27 22:36:19]
can you program that once a stop is set via the trading dom ie say a 20 tick oco stop, i do not want to be able to manually increase the stop or make it larger like it is presently able to do. I want to be able to make it smaller/tighten, but not enlarge it....please see caption
http://screencast.com/t/bSWnpfRg
[2013-06-27 22:51:46]
No. The stop order can always be manually adjusted.
