Date/Time: Fri, 27 Sep 2024 03:51:17 +0000
Chart Settings - Session Start time..
View Count: 1191
[2016-02-04 03:33:32] |
User519800 - Posts: 13 |
In "Chart Settings" setting up a Start Time for Gold and Treasury Bonds (GC & ZB) I put in 5:20 and That works, UnTil 5:30 where the letter B comes into play (giving A only 10 minutes)...B plays out for 30 minutes, as do the Rest of the letters throughout the RTH...Obviously, this needs to get on a 30 minute progression from 5:20 to 5:50, and so on...Tell me there is a Simple solution to this please...Tks....Also, I use the Evening Session and Start that one at 15:00:00 in case that needs to be considered.. D. Gestri...Evening Session works Fine.. Date Time Of Last Edit: 2016-02-04 03:41:06
[2016-02-04 06:09:12] |
This TPO Profile Chart study Input controls this: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#30MinLetterBlockSubPeriod Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-05 01:12:46] |
Unfortunately, neither of those Three Choices seems to work. I need to Begin a Market Profile Chart for Gold and the 30 Yr. Bond Starting with the letter "A", from 5:20 to 5:50 a.m., and so on with a continual "30 Minute Letter sequence" 5:50 to 6:20 etc. until at Least 12:00 p.m. there Has to be a way to accomplish this, as otherwise, these commodities cannot be charted..Help Plse - tks.
[2016-02-05 01:36:27] |
You can trust us that setting 30 Minute Letter/Block SubPeriod Handling to "Standard" is giving you the result that you want. We have confirmed this: http://www.sierrachart.com/image.php?l=1454635851927.png http://www.sierrachart.com/image.php?l=1454635881377.png You can look at the first bar in these two charts and they match. We verified that. The first bar the standard bar chart, starts at 8:20 AM and is 30 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-05 01:37:33
