Date/Time: Fri, 27 Sep 2024 03:50:09 +0000
Fibanacci graph delay on 533 tick chart
View Count: 849
[2016-02-03 20:14:42] |
User726810 - Posts: 4 |
I am experiencing delays when pulling my fibanacci graphs on my 533 and 233 tick charts. the 3,5,and 15 minute chart graphs pull normally.
[2016-02-03 21:12:43] |
We do not understand the question. What is meant by "delay"? How is it that a graph is delayed? And what is a Fibonacci graph? Specifically name the study or drawing tool you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-03 22:09:01] |
The Fibonacci price projection tool (graph) does not pull consistently in an upward motion on my tick charts during live or simulated trading. The minute chart pulls work well and consistently. What is the internet speed that you recommend for using the charts? I do not think internet speed is the problem since the person in the next office can pull his price projection tool on the tick charts consistently and we are using the same modem.
[2016-02-04 04:56:58] |
There are no drawing tools which automatically adjust after they are drawn. So we are not understanding the question. It is not making any sense to us. This has no relationship whatsoever to network connectivity. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-04 04:57:11
[2016-02-04 18:29:55] |
It does not adjust automatically. It is used manually. However, when manually applying the tool it is difficult to set the 50 Fibonacci line on the midpoint of the the desired candle on the 533 tick chart. It is much easier to set the line on the desired candle on the minute charts. If you remote into my machine it will be easy to show you what I am talking about.
[2016-02-04 18:52:43] |
You could reduce the range of prices in the chart before you draw the Chart Drawings to make the bars longer. This will make it easier. Refer to Interactive Scale Range: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScalingExpandCompress Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-04 21:57:41] |
I tried that but it did not make any difference
