Date/Time: Sat, 23 Nov 2024 11:03:54 +0000
User Email Questions - Bracket
View Count: 1477
[2013-06-27 17:12:33] |
Sierra Chart - Max - Posts: 5730 |
I’ve been trying to set up the trading dom with as follows: 2 contract bracket 1 Short or Long with 5 tick profit take with a 10 tick stop loss 1 short or long with same 10 tick stop loss but trail 15 when first contract hits 5 tick profit mark Could you maybe just send me the listing of how you would set that up in the trading dom Sierra Chart Support |
[2013-07-02 01:33:21] |
The Trade Window Configuration file for this is attached. Thank you for your patience with this. Follow the instructions here to use it: https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#ConfigurationFileAnotherSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-02 01:34:30
2 Lots With Trigger Trail.twconfig - Attached On 2013-07-02 01:30:01 UTC - Size: 6.18 KB - 633 views |
