Date/Time: Fri, 27 Sep 2024 03:50:09 +0000
Spreadsheet Sum Column Values
View Count: 910
[2016-01-30 21:02:43] |
sigmadict - Posts: 95 |
Hello, I wanted to know if there was a Function to Sum all the Values in a Column. In excel the Function if you want to Sum all the Values in Column X would be : SUM(X:X) What would be the way to achieve this task ? Thanks Regards |
[2016-02-01 06:43:48] |
We have verified that formula will work properly in New Spreadsheets. Have you tried it? It worked for us. Example: =SUM(I:I) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-05 14:31:52] |
Looks like it works. Regards |
