Date/Time: Sat, 23 Nov 2024 07:34:01 +0000
Number Bar for Stock
View Count: 1456
[2013-06-27 11:52:05] |
Moti - Posts: 63 |
Hello, -Do Sierra supply Historical data from the CME E mini futures? -I will like to connect to DTN iqfeed to receive data from the NYSE and NASDAQ On Stock Etf. Can I use Sierra charts and add Number Bar studies on AAPL IBM etc., and get a reliable tick by tick number? Date Time Of Last Edit: 2013-06-27 17:31:41
[2013-06-27 17:42:48] |
1. Yes, we do have historical data for the CME ES futures. Refer to this page: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html 2. You can use the Numbers Bars study on stocks using DTN IQ Feed data. They will be accurate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
